Hey y'all. Recently, I decided to remodel the bathroom in my 1950's house. The room has never been touched, that I can tell. I demo'ed down to the studs and subfloor. I should mention that this is my 1st attempt at such a project. I also have a neighbor that has a good bit of remodeling experience.
The issue that I'm having is this. I used 1/2" green board( actually purple) all around the room. The original plan was to install Hardi-board over the green in the tub area. Tile was to be over that. Now I have just read(on this forum) that it's a bad idea to put Hardi on drywall, due to the wicking nature of Hardi. I also did not install any vapor barrier behind the green board.
It seems to me that I have a couple of options....
1. Pull out the green board in the shower. Replace with a vapor barrier and 1/2 " Hardi- board. Then tile over.
2. Leave the green board. Prime it and buy one of the molded surrounds that will not be water permeable.
I'd rather have a tile surround, but $ is definitely a consideration. I'm also very anxious about ripping out all the work i've already done.
Any opinions would be greatly appreciated.
Thanks,
Kevin
Thanks,
Kevin
