Thanks!If you are just trying to repair the bad grout job, no need to replace the tile.
If you are looking to buy more of the same tiles, take your photos to a good tile store. (Big Box Orange or Red/Blue won't be able to help.)
No, about as far from the NW as I can be and still be in the Continental U.S. With that said, anyone know how I can update my location? I went to CP > Edit Your Details but got the following message...Do you happen to live in the North West?
https://www.google.com/search?q=mar...KAhVIFZAKHY6IC0IQsAQIGw#imgrc=LdVDDQSz0s25pM:
Thanks!I have no clue how that works. But why not try "signature"? There you can type your name permanently along with a location. Us knowing your rough location helps us give better answers. Heck you might be anywhere there's an internet connection available.
I'm not buying any marble, I just want to know what it is so I know how to care for it, moving forward and not F*** it up. TBH, I am not considering any products, yet. I just started doing research and seeking guidance on a cleaner and since you mentioned it...A good penetrating sealer.That marble is Carrara or one of several dozen other similar types. Anything you buy now will not match. Even unused spares from the same batch would look different, so do not disturb them unless you have not choice.
Clean with mild ph neutral detergent or buy one made for natural stone. Do NOT use acidic cleaners. Most grout cleaners are acidic, so be careful if you ever try to super-clean the grout. You can/should seal the tiles and grout using a good penetrating sealer. Apply several coats after a good cleaning. Post here again with our thoughts on products you're considering.
I see you're in FL. by your other thread. ok.
Jaz
Thanks!To edit your signature or add a location---go to the task bar and click on 'quick links'
There you will find what you seek---
My apologies, I should've PM'd you on this....Will do so now so I can get back to the thread topic.you will find 'user CP'---under that is 'edit signature' and 'edit details'---
If you want a bunch of options---look at the task bar--on the far left--you will see 'user CP'--that screen has more stuff you can mess with--mail--and lots more.
Thanks!JazMan said:That marble is Carrara or one of several dozen other similar types. Anything you buy now will not match. Even unused spares from the same batch would look different, so do not disturb them unless you have not choice.
Jaz
Oh...and why is that? How are you gonna avoid the tiles? Bad plan.Thanks for the reply!
FWIW, I am only planning on sealing the new grout not the existing marble.
