Hello,
I am trying to replace a Moen 1423 balancing spool. I used a force driver with a large bit to remove the brass cap that was stuck.
Unfortunately the brass cap disconnected from the silver core and it is stuck inside the valve.
I have tried to use a pick to grab a hole of the core and pull on it but I could not extract it.
Someone might have faced the same problem in the past.
One way to solve it seems to be an easy out.
Any recommendation on what to use ?
Thanks a lot,
Oliver.
Thanks a lot,
Oliver.
