1 - 18 of 18 Posts
Something like this and I think the door is open with just the edge showing. I thought the shower glasses had to be tempered so it was impossible/very very high cost, to have them made custom, but the image glass over the seat is made around the seat. Maybe this isn't american shower. Maybe it is very thick glass.
Usually, if you want glass enclosure, you need a plan first, get the glass enclosure, then build the shower/bath to fit the glass.
I would also slope the seat, fairly severely, to drain away from the opening and make sure inside corner doesn't pool water.
· Naildriver
Once you have it all tiled, call in a glass company and have them custom make a stationary panel for the left, cut to the tile offset, and an operational door fitted to the right. It won't be cheap, as it will need to be tempered.
What would my options be if I cut the bench back to make room for a different kind of door?
You are likely looking at $3000 for a nice custom glass unit.
You mentioned cutting the bench back...I’m not sure what you have in mind.
This is how our son did his...I hope this helps. As you can see, he extended
the bench out pass the shower threshold.
https://www.fabglassandmirror.com/b...MI8tTf4qCs6QIVRJyzCh3yJwJAEAAYASAAEgI4SvD_BwE
It looks like tempered glass can be cut and shaped.
Cheaper way may be to enclose with 3 pieces. Don't know but it feels as if you'd need a top channel as well because of the smaller pieces used if:
Short glass over the bench, long piece as a filler then door with hinges on the wall side. Can this door open out with the vanity? Can it open inwards and have room for person to close from inside with plenty of room? See what works.
If diy, maybe the glass seller will have the hardwares also and recommend which. It looks like 3/8" glass is the standard. If using channels, don't forget cushions that go into the channel so the glass does not rest on screws or such.
I think already mentioned by one of the posters. If you shorten the bench by 3-4 inches, yes and possible to clean as well. But this means you can't caulk the glass to the tiles in that space so you need to plan for water barrier that does not caulking. If shorten by about a foot, no restriction. As long as replanning, how about no bench at all and use a fold down bench instead? It's my preference, though, since I like plenty of room. Your photo, no depth showing and it looks like it would be impossible to clean between the bench and glass.
Discussion Starter · #12 ·
What do you mean caulk glass to tile? The tile at which location? If I shortened the bench by just a few inches then wouldn't the glass be connected the same way in all places?
1 - 18 of 18 Posts
