1 - 20 of 28 Posts
It used to have a covering over it, but I ran it over on accident with the lawnmower and it broke off. What is it and do I need to cover it back up?
If so, what could I use to cover it back up? It seems to be made of plastic or pvc pipe.
Not 100% sure but it could be the pressure/overflow tube for your drain in your house. So let say your toilet gets clogged, instead of blowing up your other ones or sink drains it will blow the cap off that pvc pipe in your backyard. My other guess is a drain for your backyard going from your backyard to the city drain on your street. Hope this helps.
· Mold!! Let's kill it!
It is either a clean out or a vent. If you can find what used to be on top you can get a clue as to which it was. If it was a vent then you need to put a vent cap back on it. If it was a clean out, then a female fitting with a threaded plug. Dig around it. Cut it off square and replace the missing parts. Extend it high enough to be above the ground, same as it was before. You need to do this before dirt, tennis balls, toys and debris get dropped into the line or tank and find their way to someplace that will cause you nightmares later on.
If it is a vent then it needs to be above the ground surface so rain water does not go into it.
· Wire Chewer
Looks like hole 18 of a mini putt course.
Yeah probably a cleanout or vent, odd location to have it outside, but actually not a bad idea. You could maybe have someone flush the toilet while you put your ear to it. If it's connected to the drain system you should hear something.
Limey,
If they have caps, then they're clean outs for your sewage. In order to be certain, use a 15" adjustable crescent to remove the cap and look inside. If it curves towards the city sewer hook-up, then it's a clean out.
Use the excellent pic Burnt03 provide above for reference.
Limey,
There is no lid or cover on mine. Doesnt look to have ever had one. I tried sniffing it last night but it emitted no smells :laughing:
My sewage clean out pipes are similar to the ones posted above, they are located close to the house and are capped off.
Im wondering if mine is water well related?
Too small for well casing and too big for discharge. Wrong grass for putting green <grin>. Possibly air vent for bomb shelter?
From the type of grass it reminds me of living in Florida. Where I lived they allowed roof drains to be piped into the storm water systems as drainage was an issue and thin wall PVC was used. So if not a cleanout for sewer or septic then possibly a cleanout for that.
I have the same thing in my yard and I am not sure what it is for. I have a septic tank system. I have been wondering for some time as to where my leech field is but this may give me a clue. I thought it was in the back of my house.
I had four of those things in my yard, as do most of my neighbors who haven't yet cut them off. There are, according to my septic installer, inspection ports at the end of each lateral. Also have one near the distribution box. Something required here but nowhere else I've ever lived. Two of mine are gone, victims of tractor hit-and-runs. Haven't gotten around to cutting off the others. Even the installer said they aren't really necessary.
· Retired Moderator
I have the same thing in my yard and I am not sure what it is for. I have a septic tank system. I have been wondering for some time as to where my leech field is but this may give me a clue. I thought it was in the back of my house. View attachment 96170
I would suggest starting a thread separate from this older thread, you may get more response.
· Usually Confused
Another option might be a dry well for eavestrough. I've only see one up here at a neighbour's house that had no slope to get drainage away from house but it looked similar to photo and was in middle of his lawn. I don't know if it was a container or just a pile of stone covered in earth. Not sure what the purpose of the pipe was - vent perhaps.
It could also be a riser for a water shutoff. Take a flashlight to it and see if there is a valve down there.
Bingo! I have a well and have the same tube.
It contains a shut off valve at the bottom for my well water. Turn it with a long rod. My well was set up with a buried pressure tank at the well head so this valve lets the water to the house be shut off while still having water supplied to the frostproof spigots by the outbuildings.
1 - 20 of 28 Posts
