What do you think this white plastic pipe is sticking out of my basement floor?
Also what do you think this pink foam is going along the entire edge of my
basement floor? (the photo shows a lot of sewage that spilled onto the pink
stuff, so it is therefore hard to see - we had a pipe break and sewage from
a kitchen sink came out which is why we busted open the drywall to find
what you see here).
In photo labeled "#2" you can see another white plastic type of pipe coming out of the floor as well.
The previous owner of my home stated that there is a french drain around the entire basement room, but is this 1.5" crevice considered a french drain?
If it is a french drain, I must say, the 1.5" crevice is the weakest french drain I've ever seen.
what you see here).
