1 - 11 of 11 Posts
My in laws had a decorative wall built 15 years ago. I saw the wall being built but only 2 stages @ the end of each day. First day they had concrete blocks assembled w/ mortar. The second day I saw the completed project as pictured. It looked like they simply painted fake stones.
Well I am in the process of painting a concrete block wall and have no idea how they achieved that stone like look using paint? I don't know what they coated the wall w/ either - stucco, surface bonding cement.
· retired painter
It could be stucco. Back when I worked in central fla it was fairly common to apply faux brick/stone made out of stucco. Basically the first coat was stucco color and then immediately a color coat was applied with the mortar joints drawn out thru the color coat exposing the underlying mortar color. Some would sprinkle/splash the color coat with something to break up the color [before the grout lines were cut thru]
Mark you are correct it is called cut Stone also used to make a brick look.
15yrs ago - could be stamped 1/4" thick vertical grade polymer-modified cements w/integral base color + next day highlight colors,,, we can make educated guesses from pics but none of us can be 100% certain,,, what's the depth of the mortar joint - 1/16" ? 1/8" ? 3/16"
we do this work basically same: trowel/spray base coat of mortar w/color of desired jnts, o'lay troweled w/thicker top coat w/different color, spray 'n' scrub in highlight colors, create random jnts using bent/folded-over metal strapping, & seal
same process for brick or stone 'cept for brick, we use straightedges
Discussion Starter · #6 ·
The mortar joints have very little depth - it literally looks like someone took there finger and drew them in the material. There are no edges in the mortar joints like you would have w/ stones set @ different depths. The mortar joints are also the same width everywhere.
When the wall was built I gave my father in law a hard time because they built the was w/o a footing and it developed a gap between the concrete & wall within month. 15 years later and the finish still looks good though.
· retired painter
I've seen them use a nice tool with a handle or just a stick they picked up off of the ground. I think the mortar would be hard on your finger tip if you used it.
1 - 11 of 11 Posts
