In my 1943 home, we have ceiling heat that does actually still work and work well. The way the ceiling is constructed is quite strange. Starting from the framing above, it has 1/2" plywood, a layer of old school gypsum board, then the wires for the ceiling heat are coiled around, then (I think a brown coat), then a white coat with the texture in the pictures below. It is not popcorn ceiling of course. It is some sort of ridged, non-uniform, texture.
We cannot remove it all and leave it flat because the ceiling is all sorts of bumpy and wavy but this texture REALLY does a fantastic job of hiding the imperfections and it actually doesn't look bad as a whole.
The problem, though, is that due to the ceiling constantly expanding and contracting due to the ceiling heat, there are areas where the white plaster has fallen off in pieces. I need to try to patch those areas with new plaster and blend it in with the same texture, but can't figure out how it is done. I am thinking maybe I put a slightly thick layer of plaster on (about 1/4") and then use some sort of non-linting towel and use it to sort of pull the ridges out. Is that anywhere close to how to do this?
