Here is what I took off the wall:
And here is what the pipe on the wall looks like, it is 2.5" long, non threaded:
I would like to get a brushed nickel replacement but what I saw in home depot all needed adapters and such. I messed around with this one model, which needed an adapter: https://www.homedepot.com/p/DANCO-Universal-Tub-Spout-in-Chrome-88702X/100344525
But had no luck and I ended up cracking the tile. Oops.
Is it possible to just buy a premade one, like the one in the first picture, where I can just slip it on and tighten a screw? For the one I removed it had a single hex screw at the bottom to tighten and release. The home Depot Hone had me lining up things, punching screws through plastic, and trying to screw things into place. I want an all in one solution.
If you look at the second picture you can see the thin crack going up the tile and the way the other had to be secured with a pointed screw (which is pointed to pierce the plastic) scratched the copper which got me worried that if I did any more I would end up cutting it and then I would be in a world of trouble.
