Can anybody tell me if there are any restrictions/requirements or best practices for running the supply wire from a main service panel to an adjacent sub-panel?
Here are my options:
Option #1 and #2 - Sub-panel main lugs at top of panel. Service wire can enter from side of sub panel or bottom. (I'm not sure if option #2 would work because I need to bend the #4 copper from the breaker in the main panel down towards the bottom to exit the panel)
Option #3 - I believe I can rotate the sub-panel "upside-down" (bottom feeding?) so the main lugs are at the bottom. (I'm not sure if option #3 would work because of the same reason as above [I can't bend #4 copper from the breaker in the main and exit the main panel at the bottom])
Here are options #4 and #5:
What is the recommend route for the wire?
(I'm using 4-4-4-6 wire (planning to use 3/4" knockouts) and 60A breaker in main panel. Both panels are Square D QO. The sub-panel is a Square D Model #QO112L125PGC)
