Just installed an attic gable fan. I cut a hole in plywood, and mounted the fan on the board, and then bolted it all to the gable. The fan fits pretty tight against the plywood and there is little room for air to escape and recirculate. The fan is on a wall switch and set to 80 F. I leave it off while at work. I also have a wireless thermometer in the attic. The readings I get before using the fan so are from 100 F to 120 F so far (two days).
The issues I'm having is right when I fire it up, the temperature suddenly starts to rise and continues for a while. It will work eventually later in the evening when the outside temp starts to go down but not until then. It has been one hour now at 73 F outside temp since turning the fan on and the temp in the attic went from 104 F to 109 F.
Inlet:
Sofits: 7 on north wall and 1 on south wall. Each- 1" x 8" w/ screen
Gable vent: identical to the one the fan is attached to (~14.5 x 19" slotted) on opposite wall.
Outlet:
15", 1300 cfm gable fan in 15" diameter circular area.
Attic area:
~1,250 sqft
What is wrong here, and what would you do to fix it if this was your house? Thanks
Inlet:
Outlet:
Attic area:
~1,250 sqft
