still do have an ant problem as that is the result of the dreaded antus concretus digesterous ( concrete eating ant larvae ) as they transition to adulthood,,, IF they get large enough AND hungry enough, your house will soon fall down :eek:
actually its efflorescence which is causing the coating to fall off,,, check for moisture behind the wall
Sure it's not just aluminum that was used as a termite shield that's falling apart because it came in contact with the pressure treated foundation plate?
