Searched the forum a bit and was surprised I couldn't find an answer to this - so I'm making my first post: Just got in a shipment of Jeld-Wen triple pane vinyl windows for my new construction. The house was wrapped very late last fall and otherwise sealed-up, and I sheathed right over the window openings, figuring to wait until spring (which has not yet really arrived in this part of Wisconsin). Reading through the manufacturer's install instructions, I find this preface for window placements into open-stud construction:
"The wall framing must be covered by backing support before the window can be installed. The window will be mounted with the nailing fin / exterior trim flush against the applied backing support. This backing support should be a non water-degradable, thin (max. 1/8" thick) sheet material such as vinyl sheeting. Completely surround the rough opening with he backing support. Backing support must be applied before building wrap."
Of course, as I said, the house is already wrapped, and before wrapping I had never heard this exact term "backing support" applied to windows. In fact, searching the whole web I cannot find these nebulous words associated with windows anywhere except in Jeld-Wen's own instructions and a couple of documents obviously pirated from those same (lots of hits on quilting and art-framing sites, though). This "backing" is not related to the drain mat or normal flashing, and I have no clue how it is to be applied or even exactly where - though from context I assume it goes directly over the exterior sheathing. Wierdest of all, a page later the step-by-step portion of the instructions begins with "cutting back the house-wrap"... Exactly where I thought I had to begin anyway.
Help! Does anybody know what the heck they are talking about?
