Set it at the highest temp you're comfortable at and leave it alone.I know comfort is individual.
I find the Dew Point temperature to be a controlling factor, not just the ambient temperature. I can take 79°F with a indoor DP of 35° but if the DP increases to 42° the ambient must drop to 76°-77° for comfort. We have a ceiling fan in most rooms and use those religiously.
I've always been told the best you can expect is 20º lower temp inside vs. outside. That may be BS? Not sure.
I can tell you we keep ours set at 68º year round. We have had several 90+ days so far and ours kept the inside 68.
Energy efficient was mentioned. Are you certain 68 qualifies as efficient?:vs_laugh:At that temperature our elect. bill would be in the $400.00 range i suspect.:vs_mad:I've always been told the best you can expect is 20º lower temp inside vs. outside. That may be BS? Not sure.
:vs_laugh::vs_laugh::vs_laugh::vs_laugh:Energy efficient was mentioned. Are you certain 68 qualifies as efficient?:vs_laugh:At that temperature our elect. bill would be in the $400.00 range i suspect.:vs_mad:
If your elect. rate is 12-13 cents / kw i want a cooling unit just like yours.:biggrin2::vs_laugh::vs_laugh::vs_laugh::vs_laugh:
Ours runs around 200.00 during the summer. But I did the math and it's cheaper than a divorce.
Yep, Elevation: 705′He's at 705 feet altitude?
:vs_smirk::vs_smirk::vs_smirk::vs_smirk::vs_smirk::vs_laugh::vs_laugh::vs_laugh::vs_laugh:I feel like I'm stalking you. :wink2:
I'm less than 6 ft. :vs_laugh::vs_laugh:He's at 705 feet altitude?
