With the tornado and hurricane season approaching, I figured it would be a good time to get a good discussion going on generators, or backup power in general.
What kind of generator are you using?
What kind of fuel does it run on?
How often do you need to use it? (or are you using it now?)
How do you wire it? Extension cords or a transfer switch? Are you running the whole house, a portion of the house, or certain outlets?
Any other backup power solutions?
Any techniques you have learned for using a generator?
Any survival stories?
I have a Generac 7500 EXL that I bought from the pawn shop for $250. It's 7500w / 13,500 peak watts. Whoever had it before me took the electric starter from it, so I have to pull start it, but it starts on the first pull. It's LOUD, but reliable.
I have 50 amp interlock that feeds the inside sub panel and isolates it from the main panel outside. The main panel outside has breakers for the a/c, furnace and stove, so the generator will run everything in the house except those 3 things. The generator has a NEMA 14-50 plug on it, so that's what I used for all the connections, including a 10 AWG, 4 conductor extension cable that I run across the back yard to a detached
porch.
I also have 2 400w battery backups in my living room and home office to keep the cable box/dvr running (it takes 10 min to reboot) and computers in the office running until I can switch to backup power.
We just had some bad storms come by last week and the power went out in the next neighborhood so I figured it would be a good time to test it and run some gas through it. It ran everything in the house including the washer, dryer, hot water heater if I ever needed them but id probably just keep those breakers off to save fuel.
Funny, before I bought the generator the power went out all the time. In 3 years since, I've never had to use it.
I was thinking of converting it to run on propane so I could store a big tank.
I've also heard of "microturbine" generators. Anyone heard of used one?
I was also thinking of buying an enterprise class battery backup, 3000w or so, one with bad batteries for cheap. I could then just get a bank of car batteries to extend the runtime. I could use that to power certain rooms in the house so I don't have to run the generator and attract a bunch of attention to the house.
Anyways, let's get a good discussion going here. Im interested to hear what you all have to say.
porch.
