I posted this in the contractors forum but I didn't belong there, sorry.
Anyway, copied from there:
I'm doing my kitchen with Ditra XL and have run into a little problem. It's actually pretty damned big as it means I've wasted a lot of time and have to do everything over again, most likely. The Ditra doesn't seem to be sticking to the modified thinset.
Subfloor: 1x8 diagonals, original from 1955. Screwed down to the joists 16" OC.
On top of that: 5/8 T&G exterior grade plywood screwed down to the diagonals. 4 inches on edge, 8 in the field
Thinset: Mapei Ultraflex 2 - the bag was about a year and a half old
Trowel: As recommended by Schluter without buying their overpriced one.
Method: floor dampened with a sponge. Thinset was fairly fluid but still held a ridge. XL applied, then pulled up. Sure enough it had only about 60 percent coverage so I had to put down more thinset and try again. That got pretty tiring. I seem to have to do that everytime I use Ditra.
And my reward for all that work and money? While vacuuming I notices some of the XL pulled up. I began to cut up the parts that weren't stuck.
I've talked to my supplier here and he's trying to get in touch with the Mapei rep. I'm really disappointed and a bit angry about this but what can I do? So...what can I do?
What do you guys think was the failure and, more importantly, how do I fix it?
In addition:
BTW, I've started to pull up the rest of the Ditra. Comes up easy as pie with a slight zipping sound. That thinset didn't stick to the XL fleece. I believe I could use this Ditra over again if I had to.
I'm using a putty knife to bring up this thinset now. Some peels up easy and some doesn't. Either way it wouldn't matter the fleece is simply not firmly embedded in the thinset. Still waiting to hear from Mr Mapei but who am I fooling...it will be all my fault...even if it isn't, if you get my meaning.
Right now I'd love an idea of how to get this junk off my floor. At the rate I'm going it will take days. I think I'm going to be switching to Laticrete...I have no idea why I feel that way.
In addition:
