I want to get a data logger (a device you attach sensors into and it takes measurements every x minutes which you later download to your computer so you can graph the data). One thing I want to track is my electric water heater element (a Rheem model 82V120HE-1) which the manual describes the electric data as
"Heaters furnished with standard 240 volt AC, single phase non-simultaneous wiring and 4500 watt heating element." and it's on a 30 amp breaker.
Will the sensor below be able to measure when my tank draws amps (the sensor is an Onset CTV-B, the data logger an Onset U12-006) it's described as
"A split-core AC current sensor responsive over the range of 0 to 50 amps AC for use with U12 data loggers with external input channels. With an input current of AC current, sine wave, single phase 50 Hz or 60 Hz, load power factor 0.5 to 1.0 lead or lag."
It's looking like it will, except I have no idea what split core means. Thanks
