It's my first post on the HVAC side of things. I'm the first to admit HVAC is out of my lane. The answer may be obvious. But I have no clue how to tackle this.
Situation: Unsure how to handle a 6" supply that fed a toekick register under the kitchen sink base cabinet.
Background: Remodeling my kitchen after a dishwasher leak cause a partial loss. Old cabinets had a toekick register. The was custom fabricated and the water mediation company damaged it beyond repair when they removed the cabinets. I'm laying a 2nd layer of plywood in preparation for tile before the cabinets are installed.
Assessment: It's a 6" 90 degree elbow that comes up through the subfloor. Terminates flush with the subfloor. It will terminate underneath the kitchen sink vanity.
Problem: The cabinet installers said one cost effective option is to caulk the cavity under the kitchen sink base. This would prevent warm air leaking into the cabinet. Then cut out a toekick register.
I'm open to that option but there's a large gap between the subfloor and 6" duct. I don't want warm air pushing back down into the laundry room below. I could block off gap from below easy enough.
However, is there some boot or flange I should be installing over that 6" crimped end? It's held from below with a metal strap. I browsed Home Depot and didn't find any part that would address a situation like this.
I'm at a loss and want to get 2nd opinions before I install the plywood underlayment.
Thanks in advance boys!
