The ceiling blocks began to fall and the plaster walls were cracking underneath years of paint.
My wife and I decided to pull down the ceiling and walls, add updated wiring, a ceiling fan and presto we have a new room.
I should have known better.
We are at the point now ready to drywall the room. We started with the ceiling but found that the joists are uneven and the room is out of square. This caused the drywall screws to pop through the drywall.
Further investigation found that the lowest joist on the east end of the room was not the lowest joist on the west end of the room and that obviously the lowest joist on the east end did not necessarily carry the length of the room as the lowest point.
We have been speaking with people who have told us two different methods to help complete our task of evening out the ceiling joists for drywall installation.
The first being 2x4 across the joists every 16" filling in the gaps with shims.
The second a bit more complicated but makes a bit more sense is that since the room is not square, the walls are not of equal height we should find the lowest points in the joists the length of the room and apply the 2x4 to the sides (sistering) of the joists.
Both make sense to us, and both choices confuse us as to how the final appearance will look.
We are not looking to re-frame the room in hopes of getting it square, we are looking to accomodate a proper ceiling in an old home (over 110 years old) with lost of settling and some slope.
Your thoughts and ideas would be appreciated.
Thank you.
Thank you.
