Hi all,
I wanted to upgrade to a WiFi thermostat, so I went out and bought the Honeywell RTH9580WF from Lowes. The first unit I bought popped up a warning saying the wifi radio doesn't work and to replace the unit. So I went back to Lowes and got a second unit.
My original thermostat was also a Honeywell and I have a heat pump system. The wiring was all labeled identical between the two thermostats and the setup on the new thermostat just asked if certain wires were installed so I'm positive I didn't wire anything wrong.
Everything booted up fine, connected to wifi just fine and setup went smoothly. I turned the AC on and I feel neutral air, that eventually turns into hot air. I walked out and my fan was spinning on the AC but the compressor was warm, and the lines running to the thermostat were not cold.
I don't want to think I bought 2 bad units from Lowes in a row but it is possible. Does anyone have any thoughts on what could have caused the compressor to not kick on? I reinstalled my old thermostat and everything works again.
Thanks,
-Drew
Thanks,
-Drew
