1 - 11 of 11 Posts
So I am about to take on my first drywall ceiling repair project. Due to some water leakage over the years, a section of my ceiling has softened and deteriorated (see photo).
I have since repaired what was causing the leak upstairs and I will be cutting out that section of ceiling.
After watching several YouTube videos, I am confident that I can complete this project. I will be buying a 2ft by 2ft drywall patching panel to repair the ceiling but I am having a bit of difficulty determining what depth to get. I cut a small piece of my ceiling to measure the depth of drywall. I know the actual drywall is from paper to paper, but there is also that layer of (I am assuming) joint compound/paint/plaster. If i measure just the drywall portion it is 1/2 inch, if i measure the whole piece including the layer on top, it is closer to 5/8 inch (see photo).
Which depth should I get for the repair? Common sense tells me to get 1/2 inch and after joint compound and paint are applied, it should theoretically even out with rest of the ceiling. But I am not sure so I welcome any expertise.
Thanks!
Hi, looks like you cut into a joint and the compound would be a bit thicker, go with the 1/2鈥, try to locate the ceiling joists so that you can securely mount the drywall, not necessarily 2鈥橷2鈥, also before you tape the joints, try and cut back the paper a bit on the drywall so that the tape will fit flush, apply the compound, tape, and go over with a wide blade putty knife or equivalent, you will probably need more than one coat.
Geo
Thanks for the info, that makes sense.
also, is it possible that that layer of plaster/compound/paint could be spread around the whole ceiling? I cut another hole closer to the damaged area and the layer still seems to be there. I guess i just want to be sure that it is definitely drywall and not something like plaster on gypsum lath - Not sure, Is there a big difference? - I'm learning... haha
retired painter
It almost looks like drywall with a plaster veneer. It's better to for the patch piece to be shy and build it out than have a piece that is too thick. You can either shim it to fit or add a setting compound over it to make it flush.
You're cutting out a piece at the joint, which is where the joint compound is added, and specifically in the middle of the joint where the compound will be thickest. So you have 1/2" drywall. Follow the correct videos for drywall work and you'll be good. I recommend using FibaFuse tape, rather than paper or standard mesh tape.
Plaster is quite a bit harder usually. When you do a drywall joint, it can spread about 20" in total, tapering down as you move away from the joint. If it's 1/8" thick at the joint, it will be about 1/16" 10" away.
In any case, it doesn't matter. You're going to be using joint compound to feather out this patch to make it look smooth and flat. It's an illusion - technically they can never be perfectly flat.
1 - 11 of 11 Posts
