I just bought a home that has well and septic and everything seems to be fine, but I like knowing my hardware. I have installed RO filters in the past under sinks but a well water system is a bit out of my current league (not that I cannot learn).
I wanted to share some photos and need help identifying the parts and basic maintenance and if there are any concerns.
This is the general setup:
1. Is the sale storage container for the water softener correct? I filled it all the way up. Assume that is ok. Took about 6 bags of salt.
2. This looks to be a dual stage filter of some sort... not sure what it is for. What do I look for?
3. Appears to be an expansion take for water pressure. What is the correct PSI of this tank supposed to be?
4. This tank/filter seems to have a timer or gauge on the top. I am not sure what this is for and what I should look for on it.
5. This small tank holds oxidizer (7% H2O2) - I am told by the previous owner to add one cup each week. There looks to be paper filaments at the bottom (circular that are starting to get rust coloration on the edges... could be normal). What is this for? What other maintenance is needed?
6. This looks like an RO filter for the drinking water at the kitchen sink and the fridge inlet for ice and water. This is basic for me and can install new filters when needed.
7. This is the first filter coming from the well... I assume this is a first stage filter?
8. RO pressure tank I assume. What PSI?
9. Sump pump to expel water...
So with all this... are there manuals online for this system type? Are there cheaper online services for me to replace certain things instead of buying local? I need some general guidance here for anyone that has one of these type of systems.
Thanks!
Here are additional images:
Thanks!
