it may be a bad check valve, allowing water to slowly seep past it and back down the pipe, thereby lowering the pressure?
DM
DM
If no water is being used, and the pressure falls, you have a leak. It is not anything to do with the pressure tank unless you see water on the floor.well its a 20 gallon wx-202 and i've lived in the house for 10 yrs so i know the tank is at least that old. i dont know if it has a bladder or not. mine fits into the category of taking a few hrs to go from 55 to 28 but it does go into the 40's inside of 15 minutes. it will go to 35 in about 3 hrs and to 28 shortly after.... i do have a ice machine on the frig but i have only 2 toilets and i checked them both and neither are leaking. i have no leaky faucets or anything else that i could see... do i have to cut the power off before recharging the tank ?
