have an issue with the well pump and air tank. Bleeds water through the air valve stem so I guess it needs to be replaced? currently is a Sur-Flo SF20 model manufactured in 2002. Well pump is 2hp, 1hp is on the tank lable...do not know if this is the challenge?
When the water is full on, the pressure goes up and down every five to eight seconds and a noticable bang where the air tank is located. Will I ruin the system upstream of this if I continue to run the water prior to the repair folks being able to get to it? (having problems getting the plumbers attention)
