The gauge on my well pump leaks. It will kick on, move from around 70 to 50 after a few minutes, then kick on and jump back to 70.
I turned off the main water supply to the house that is located right after the holding tank to see if I had a leak inside and the gauge still dropped. I then had someone out that thought the pump and holding tank was okay and said the leak was probably outside. The only thing that is hooked up outside is a frost free spigot that does not seem to be tied into the holding tank. There are no pipes that run to the outside. He said it probably wasn't worth digging around for since it was such a slow leak.
What I noticed is that when the water is running inside, the pump continuously kicks on. If I have the frost free spigot running outside the gauge on the well pump stays in one spot.
Any ideas on what this could be or what to look for. The advice about just leaving it alone doesn't seem right.
