How do you bleed the air out of the pipes for heat?
R rwiwczar · Registered Joined Jan 23, 2013 · 1 Posts Discussion Starter • #1 • Jan 23, 2013 How do you bleed the air out of the pipes for heat?
Bondo · Master General ReEngineer Joined Dec 8, 2007 · 9,793 Posts #2 • Jan 23, 2013 Ayuh,... That'll depend on the type of radiation used, 'n how it's plumbed.... Baseboards usually have bleeder screws at the higher points in a loop.... Is the boiler runnin', 'n up to pressure,..??
