Last week I posted about the well not pumping into the house (moderator, please don't bury this post under the old one).
Today I finally got the blockage in the line cleared out using my air compressor, but I'm utterly confused about what/how the system works.
When I was working on the well, I saw where the pitless adapter was, and I dug down to it on the outside of the casing and cut the water line to ensure it was flowing.
When I first tried to clear the line (water wasn't reaching inside the house), I kept expecting bubbles to come up in the pool of water inside the hole I dug.
When it finally cleared today, there were plenty of bubbles, but not from the supply line as I expected.
The bubbles were coming from inside the well casing!
I currently have the water line severed just outside the casing.
Some small amount of water is running out from the pitless adapter into the hole, but the line that I thought was running from my well to my house isn't even part of the equation.
Can there be a second line going through the well casing and running into my house? I only saw the one pitless adapter.
I do have water at the barn in the other direction from the house but I assumed the water line must have a TEE somewhere underground going to house and barn.
In short, how can air that I'm pumping from the line under the house that I took off my pressure tank be blowing bubbles inside the well casing?
Thanks.
Thanks.
