As we've seen in my previous thread, First 2 projects, the bathroom was completed a while ago. I've been working on the rest of it. I've done a large part of it myself. I've also had help from the good people here. In addition, I did have an electrician work with me. Painting begins this weekend.
Here's what it looked like 10 years ago:
The far wall is wired for a flat screen and sound. I've also wired for a projector.
The new doorway to the mechanicals room. I originally made the door wider and then realized it wouldn't matter if I couldn't get things through the basement door. (duh)
Screen wall that's been drywalled.
Now we see the other end of the room. Note how far away from the wall the HVAC is located. Also follow the main stack through the wall and the middle of the aforementioned bathroom. I moved the HVAC and extended the stack to the end of the room and then made a right.
You can see the new location for the HVAC. The soffits are 7'10 above the floor. The main ceiling is 9 feet. Also, the basement ducts have been installed.
Another picture with the new HVAC. The elevated box is for the right speaker in the 7.1 system.
This is the bar area. You can see the wall of the bathroom
This is closeup of the bar. You can follow the stack through the soffit. You can also see where I cut the pipe.
Same area with drywall.
10 Picture limit. To be continued in next post.
