It's not a dimmer switchChange the dimmer .Make sure your new switch is led compatible.
Remember that we need to know how many CABLES are connected to the lighting outlet box with the malfunctioning LED Light AND how many cables are connected to the switch box were the light switch for that light is located. That will tell us a lot and reduce the guess work.Tom, thank you for the time you took to reply. I think i understand what you're trying to tell me. Since this house was built in 1956 it is all 2 wire copper cable. The circuit is a single cable supplying 5 boxes. The doorbell transformer isn't attached to a box. It was simply screwed to a ceiling joist. From what i could see when i was up there, it is spliced into the cable just before the box with my problem light. It is heavily wrapped in old cloth tape. I'll go back up tomorrow and try to get a better look. And maybe a picture or 2. Again thank you and every one else for all the help.
Tom Horne
First things first, Tom Horne, apparently God loves me. It is solid copper wire.
3 cables going into box. 1 for the feed in, 1 out to next box, and 1 to the switch. After "Crawling" around the 4 foot tall attic thru 2 feet of insulation i found the feed wire for the transformer and it was wired in with the cable going to the light switch. No reason why. Removed it and capped off the wires and the light works as it should. I then ran a new cable to the doorbell transformer from another junction box and it now works as it should. The only reason i can think of why this wasn't happening before i switched to led is because incandescent bulbs need more power to light. I used 12/2 Romex wire, proper wire caps and electrical tape. I used strain reliefs in the boxes to prevent the wires from being pulled out. Thank you everyone for all the great information and help. Greatly appreciated.
You were correct. It was wired in with the switch and I have no idea why.Let's go to the transformer issue. With your fluke tester, what is the voltage to the transformer with the center switch both off and then on.
Well that reads like it was no fun at all! I have one more detail that you need to take care of. You may end up cursing me thoroughly for not remembering to tell you this earlier. The wire leads that are part of the transformer are supposed to be spliced to the wires of the cable supplying them inside an electrical box. If you look carefully at the transformer you may find a mounting mechanism that allows you to attach it to 1/2 inch knock out so that the transformers supply wires come out of the transformer were it is directly on the knockout so that they end up inside the electrical box.Tom Horne
When i ran the new cable i did put in a new junction box and attached the transformer thru the knockout just like the 4th image.Well that reads like it was no fun at all! I have one more detail that you need to take care of. You may end up cursing me thoroughly for not remembering to tell you this earlier. The wire leads that are part of the transformer are supposed to be spliced to the wires of the cable supplying them inside an electrical box. If you look carefully at the transformer you may find a mounting mechanism that allows you to attach it to 1/2 inch knock out so that the transformers supply wires come out of the transformer were it is directly on the knockout so that they end up inside the electrical box.
View attachment 728200 View attachment 728206 View attachment 728201 View attachment 728198
The 1st one on the left is held in the knockout by the screw. 2nd is how it is held in the knockout by the screw. 3rd is held onto the knockout by a locknut. 4th is how it looks when mounted to the outside of the box with its primary wires on the inside through the knockout. Only the small doorbell wires can be connected or spliced outside of an electrical box.
The supply cable goes into the box through a cable clamp approved for that type of cable. Non Metallic cable jacket must extend inside the box for 1/2 inch beyond the clamp. The wires will need to have ≥ 6 inches of wire beyond the end of the cable jacket. The wires must be able to extend ≥ 4 inches beyond the box opening. Connect the Equipment Grounding Conductor (EGC) to the box itself. If the transformer has a green lead wire splice a jumper in with the EGC from the cable and the green lead from the transformer. The jumper goes to a green screw in the box itself.Connect one of the transformers lead wires to each of the insulated wires in the cable. Gently fold the splices back inside the box and install the cover. The reason for having a box is to contain the products of an arcing fault or connection long enough for the fuse or circuit breaker to open and de-energize the fault before it ignites a fire.
Tom Horne
I think The transformer was somehow connected across the switch in series with the light.When i ran the new cable i did put in a new junction box and attached the transformer thru the knockout just like the 4th image.
Oh good. Your careful execution of the rewiring saves me from being a total goat; with apologies to goats everywhere. I was afraid that I had failed to react quickly enough to your stating that the transformer had been attached to a rafter rather than a box.When i ran the new cable i did put in a new junction box and attached the transformer thru the knockout just like the 4th image.
