hi all. i recently bought a house that has 2 gas powered heat systems. there is a steam system that heats the original house, and a hot water system running off a weil-mclain CG series 11 boiler / standing pilot ignition system.
i'm having trouble with the hot water system.
in my attempts to diagnose, i turned it off, and then back on awhile later. when i turned it on, it fired up, the flue opened, and i thought i was all set. however, after about a minute it turned itself off - despite the fact that the thermostat was still in the on position - and the flue closed.
i should mention that a few weeks ago i had the baseboard moved. it had previously been bumped out into the room under a built-in tv/book case that i got rid of, so i had a plumber come in and bring the pipe back against the wall. after seeing it done, i thought to myself, "i could have done that and saved $300" b/c my understanding was that all that happened was they drained the pipe, took out a few elbows, and put the pipe back together.
anyway, it has finally gotten cold here in the northeast, and i am noticing for the first time since the baseboard was moved that the heat isn't coming up. i'm not sure if that is related to the fact that the system was drained (meaning maybe they didn't put enough water back in etc?) or if it is totally unrelated to teh baseboard thing.
anyone have any thoughts? i have had 3 different plumbers in the house since i moved in and the thought of calling another makes me want to puke, so if there is a simple fix here, i'd love to hear ideas.
thanks
thanks
