1 - 6 of 6 Posts
Hi,
I currently have 2x16 16" oc solid wood joists in the basement. There are five to six 3/4" holes already drilled in each joist to run the original electrical, all of them only 1" from the bottom instead of the 2" required for structural integrity. So far after 6o years the floors still haven't caved, but now I need to run new electrical for new lights. I will need to drill two 3/4" holes on each joist.
Does anyone know how many holes I can drill in a joist without further weakening it?
Thanks!
whew! I was going to say that's some custom framing......
here is the 2009 International Residential Code limitations for notching and drilling of floor joists (your code may vary). This will indicate where (outer 1/3 of the joist span) and sizes allowed in those areas. Just be aware the more holes/notches placed in an area the less strength there will be in the joist.
Hope this helps! Good luck! :thumbsup:
1 - 6 of 6 Posts
