we have a kitchen vinyl floor that is glued down on a cement floor we would like to lay new self adhesive flooring over it can this be done or is it better to take the old tile off and use adhesive to attach the new tile.:( Jim
Retired Moderator
Jim---A lot will depend on the sheet goods----if it is not a soft ,padded vinyl
you can go over it ---with some preparation.
If it is embossed (not flat) you will need to use an embossing leveler--
Tell us more about this floor.
Reactions: jttcjbt
If your talking about peel and stick tile I can not warn you enough againt it.
It shrinks over time and gaps open up.
There's going to be some that will just not stay stuck down.
Near imposable to lay in a straight line because they like to stick before you can get them in place and can not be adjusted without breaking.
There so thin there going to show any flaws in the floor.
The color is only on the surface.
In most cases if the old floors in good shape you can go over it with new sheet linolium and have a seam free floor.
Reactions: jttcjbt and oh'mike
I agree 110%. The peel n stick vinyl tiles will develop gaps between them within 1 year.
