1 - 11 of 11 Posts
Last year we purchased a small (1200') older (1947) home in Boynton Beach Florida. The house originally had two bedrooms and one bath. Somewhere along the line the garage was converted to a bedroom and what I think was originally the laundry room was converted to a half bath (sink & toilet) This converted garage/bedroom has an outside backdoor that opens to a 6x12 foot pump room that now has a washer & drier in it. Years (and years) ago someone tapped into the sewer line and ran sewer and hot & cold water into the pump room. When we got it, it had no roof and no pump. We fixed it all: installed a new pump and put in washer and drier. Has turned out to be a very nice little washroom. Anyway back to the outdoor shower.
I love DIYing and the idea of a three bedroom house with only one shower just didn't get it. Unfortunately we didn't have the $10-15K it would take to try and put an inside shower in. I started looking at outdoor shower kits. The bottom line was that most would end up costing $1500-$2000 by the time I was completely done. All of them were also much higher (taller) than I wanted it to be, around 8'. So I said “what the heck”, I can teach myself to solder and I can build the whole thing myself for about $600 – which turned out to be completely true.
So here are a couple things I found out. Learning to solder copper pipe is fairly easy. The big box stores carry a very low grade of rough cut cedar. I was lucky in that I already had all the power tools I needed ( compound miter saw, circular saw, sander, table saw, various drill bits, all the stuff to solder, etc).
I found a picture of a copper pipe shower tree and copied that for water hook up. Have a rain shower head and hot/cold water outlets at bottom of shower for whatever reason may arise. I used rough cut 4x4 cedar (sanded down with belt sander) for corner posts. I used cedar 1x6 tongue & grove on 1x4 supports for walls. One side of the T&G was smooth and finished so had no prep work for the walls. I build the door out of left over scrap pieces of wall T&G and a 1x4 cedar frame. The floor is an area about 4'x4' filled with drain field stone and topped with a cedar platform. The shower door is about 10' from the bedroom back door. To top it all off we enclosed the area with a fence & gate for a nice little privacy area. All in all it turned out as a great little project and I love taking outside showers.
If anyone has any specific questions on this project just ask.
See photos in post #3
· A "Handy Husband"
Nice looking job. My concern is that without a drain and using soaps and shampoo, the area will become a soggy, slimy mess. I see you have stone for drainage underneath, is there anyw:wink2:ay to connect to an actual sewer?
We are using "green" soaps and shmpoos. The ground is pure sand, water runs out like there is no bottom. BUT, the sewer line for washer runs right under it and we may do a more permanent solution one day. There are also some code issues with making it a "permanent, plumbed" shower.
· A "Handy Husband"
Local requirement in my area: only cold water for outside showers without drain. Basically beach shower.
Does anyone know how to rotate the pictures right side up?
Mods can do it. I don't think members can.
What members can do is always drop their tall image onto a wide white background before uploading it.
Nice Looking job. But I too fear that the surrounding area will become a bug infested mess overtime . Natural cleaning agents don't really break down fast enough to help. Eventually the soaps and other stuff that is rinsed off your body will clog the sand pores. It's the reason you need to backwash a sand pool filter every so often.
Nice!!! I have a little house in the Outer Banks. This type of shower is very common there. No one has a drain. The soil is so sandy I could take an hour shower and not leave a puddle. Bugs are not a concern because there's no standing water. Building practices vary greatly inside the U.S. What OP did is fine!
Discussion Starter · #11 · (Edited)
yes, you can turn a hose on full bore and it will make a puddle about a foot wide and the water just runs down into the sand forever. We will see how things go. I can put in a drain if I want to because the washing machine drain into sewer system is actually under the shower.
PS: the outdoor shower has proven to be awesome and a great addition to house; almost as good as having a second indoor shower. We are adding rubber tile flooring to the area, more pics in couple weeks.
1 - 11 of 11 Posts
