Waterproof Deck Options
Looking for some opinions:
The Meat:
I built an elevated deck 7years ago off my walkout. We used Ducan's Roll Dek to create water a proof seal and a dry area underneath. The deck has received 3 refresher coats since, but developed a crack at one of the seams last year. Repaired it, reappeared again this spring. Looks like the plywood has gone soft and will need to do larger repair. Particulars:
· 11' x 24' deck with 4x4 landing and diagonal for house. 4 boxed in tele-posts
· Header is 3-2x10 (16’ s and 8’s sandwiched) PT 16”OC
· 2x10 joists on hangers PT
· 3/4” T&G PT
· Ducan Roll Dek (rubberized paint on deck seal.)
The Potatoes:
For the bad seam, I’m going to cut out a 48”x30.5” section. Marry some 2x6 PT to the outside joists (glue and screw). Glue and screw 13” x8” ¾” PT plywood between the joists. Then glue and screw a new 48”x30.5 piece of ¾” PT plywood. (hoping the joist is in good condition. Now to recoat.
The Gravy,
The Roll Dek has been okay. Stains pretty easy and seams to leave gray deposit on bare feet and damn hot in the summer. So I’m thinking to change it up. Ideas I’ve considered:
· Re apply Roll Dek and redo ( Not first choice not all that happy with the look)
· Sand and apply Dura Dek (Seen a number and not that happy with the look and seam)
· Sand and apply Tuf Dek (seams to be higher grade of Dura dek and the local hardware store thought you could heat join the material instead of lapping)
· Seal Re seal deck and install a floating tile: Coral Simple Flooring Solutions (it’s little sketchy, HD has it but I can find no info on the web, and I’m not sure how to work around the rail posts)
· Sand apply thinset and Schulter fabric, thinset and tile. Not sure if I’d still have cracking with a lot of work.
Has to survive the -40deg winters. Any thought on options or other suggestions?
The Meat:
· 3/4” T&G PT
The Potatoes:
The Gravy,
