Planning on gutting bathroom and tiling walls. After I gut the walls down to studs, I was planning on stapling felt paper as a moisture barrier and then hardy backer. After research I discovered redguard. With redguard can I skip felt paper? Was thinking just putting up hardibacker directly to studs, then applying two coats of redguard. Does this sound accurate? Thank u all in advance!!
