I am trying to wire an 8-wire White-Rodgers Big Blue (model 1F95-1277) thermostat to accomodate 1 cooling stage and three heat stages. I want my Hydronic Water heat pump to be the first stage heat, the Hydronic Forced Air to be the second stage heat and the electric heat strips to be the third (or emergency) stage heat. The thermostat wires go to the Hydronic Forced Air unit, which has a 4-wire interface with the Hydronic Water heatpump. The confusion factor is mostly around the thermostat wires connected to the following terminal designators:
Y1 - I want the Hydronic Forced Air to be a single stage cool, but second stage heat, so I don't know how to get the signal to the Hydronic Water unit.
Y2 - I think the thermostat Y2 should be connected to the Hydronic Forced Air 2nd stage heat connection
O - Seems like it is obvious and should be the Hydronic Forced Air reversing valve call at terminal O
B - Should this go through the Hydronic Forced Air interface wires to the Hydronic Water reversing valve terminal O?
W2-W/E - Should they be jumpered, or separate. If separate, I think that the W2 should go to the Hydronic Forced Air teminal W, and the W/E should go through the hydronic forced air interface wires to the Hydronic Water terminal W1. If jumpered, do I just connect the one thermostat W2-W/E to both the Hydronic Forced Air terminal W and the Hydronic Water terminal W1?
If it matters, my Waterfurnace Hydronic Forced Air Heatpump is an Envision 208-230/60/1 and my Waterfurnace Hydronic Water Heatpump is an E-Series EW042 model.
Thanks to anyone who can help me decipher this. I installed it myself two years ago, but this is the first year that I got the radiant floor heating ready for the mainfloor because until now the forced air was heating the mainfloor and the radiant floor was only heating the basement slab.
