Our pressure switch turns on and off consistently when water is running.. we replaced pressure switch and did not fix it....so i read our pressure tank should has 2 psi...so i press in the shreader valve on the tank...no air comes out or water...so we try to put air into the tank and it wont go in or something because after we try still no air when i press in the shreader valve....what to do..please help
