Water under furnace humidifier too
I have the same problem. The leak started after a furnace technician replaced the solenoid valve. I noticed that he fully opened the needle valve. The pump immediately started "flushing" several times an hour. The leak turned into pool. It only stopped when I closed the needle valve. Water is clear, hose and tubing are intact. There are no visible obstructions or kinks. I am reluctant to open the needle valve until I know the cause and can fix it.
What is the most likely cause of the leak?
Thanks to all who respond to this post.
Bratt
Bratt
