The hot water from my faucet went from normal to a slow flow, to a drip. I was told that most likely my problem is that there is sediment built up in my hot water tank (i'm on city water). So I was advised to drain the tank and change the head where my water tank meets the hot water line. I have two questions:
1. How do I remove the head connecting the hot water line and the tank? It has sealent in the threads and I'm not sure of the best way to remove the head without damaging everything.
2. How do I clean the inside of the tank prior to refilling it. I've been told that if I refill prior to cleaning, I may have just made my problems worse, by now forcing the sediment into my pipes.
Please help.
Please help.
