The water supply for the house I am renovating comes from a spring on a hill behind the house. The water pressure is gravity fed. I am currently redoing the plumbing in the house and I picked up a booster pump to help with the low pressure(16 psi at the main). Now I am wondering if I should add a storage tank before the pump so it doesn't run dry, and what type of tank I should get.
Thanks,
Thanks,
