i was thinking of making a water purification system to filter out some of the nasty stuff in modern tap water... microbes have been an issue here in the past as well as fluoride and id like to turn tap water into spring water quality
i could possible build a water still, or reverse osmosis setup which will essentially strip the water of all chemicals and microbes, but isnt good to drink long term unless i add minerals back into the water... so one of these systems with possibly some kind of mineral tablets would be good, so long as its inexpensive enough to add it to three to five gallon jugs regularly
my other option is a filtration system using multiple filters... an activated charcoal filter to filter out most the bad stuff, and possibly an activated alumina filter to get the fluoride
any suggestions on which direction i should go, and the best way to build such a filtration system?
