1 - 6 of 6 Posts
I we just changed the bladder tank, and the water pressure was good for a day or so but now only the water pressure inside is low n the tank keeps turning off n on when we use the water inside the home, but works fine when we use the outside water
· the Musigician
The 'swap out' simply referred to you 'swapping out' the old tank for the new, it is not an item to look for.
Is the indoor pressure low at ALL fixtures/faucets?
DM
· the Musigician
Unscrew the cap on the end of the faucet and check for loose particles that may have broken loose and gunked up the faucet. That may be the only problem. *cross your fingers*
DM
1 - 6 of 6 Posts
