This past winter, after snows and then rain, my water pump chamber, which is in a cinder block housing sitting underground and outdoors began leaking water into it. It caused the jet pump housed inside to get submerged and to fail and needed replacement.
I have dug up the ground surrounding the chamber and the water pipes feeding water to it. Some of these pipes are only 18 inches deep but never froze in the 14 years I've been here. My house is in northwest Connecticut.
I'd like to know how to best now protect these pipes from possibly freezing in the future.
I do not know whether to put gravel in the now open trench and how deep. Or just to put back the dirt, or use sand. And should I cover the trench with 2 inch rigid insulation, and if so, how to attach the pieces before covering with dirt. And how wide should this rigid insulation be? And should I first use some foam pipe insulation around these underground pipes and how do I best connect the lengths. It is 1 inch copper pipe that is buried in the open trench.
And I plan to clean the outside of the pump chamber and cover it with tar and surround that with 3/4 inch gravel. Is that a good idea?
Art
Art
