Had a similar problem with theach electrical bill.I always question utility company data comparing our home to our “comparable” neighbors. In NY I changed our single outdoor light to an LED and our home is vacant for 3 months per year while we are in FL. The only electrical devices running are the outdoor light, the high efficiency furnace and occasionally the sump pump. We also let the refrigerator and freezer run. During the 3 months while our house is empty we still use a little more electricity than our “comparable” neighbors who have occupied houses. Bull crap.
First thing that I would do is shut off your water at the house, then go see if your meter is moving. If it is, you may have a broken service line outside.Hi there. Water consumption in my house is high since we bought the house. No leaks for sure (when we left for a month, the usage was none); also in the past 1-2 years, we've renovated all bathrooms, installed water efficient toilets, showers, faucets, etc.. No long showers, no frequent laundries either. Per water company data, our water consumption is above average and for sure higher than my neighbors I talked to (with bigger houses, more habitants, daily yard watering).
And no, I don't use sprinklers. I occasionally water a few plants with a hose.
I suspect that a water meter faulty it shows e.g. 2x more what we use. Technically, I don't have access to it (it is in one of those locked boxes buried at the property line). I called the water company asking for a validation, but I was disregarded.
What's the procedure of conducting an audit of actual use and who can do that? I would prefer NOT to cut my main water line to install the 2nd meter inside my house to compare indications.
Thoughts?
Thanks!
J.
The problem that the OP is trying to work around is that he does not have access to the meter.First thing that I would do is shut off your water at the house, then go see if your meter is moving.
I used to go to various properties but I did not enter if a dog was present. You know your dog and your dog likes you. That doesn’t mean your dog likes me. Some dogs can be unpredictable around strangers. If you want me to enter to do my job, your dogs need to be put away or restrained. Personally I don’t particularly like or trust dogs for various reasons not pertinent to this conversation. Many dog owners assume that others like their dogs, which is not the case.Had a similar problem with theach electrical bill.
At one time I had dogs in the back yard.
No problems with the dogs going after the meter reader, until a new meter reader took over the route.
First thing the new meter reader did was hit the dogs with his clip boars and spray them with mace.
These dogs might lick you to death, but never bit anyone.
Electric bill almost doubled for a couple of months for no apparent reason.
Figured out they were estimating the bill based on the usage of the homes in the neighborhood.
When asked why, I was told because my dogs wouldn't let the meter reader in the yard.
Made arrangements to have a post card sent to the house, on which I drew the meter dials, and sent it back.
They made appointments to verify my meter every six months.
Did I get reimbursed for the overage?
Yes, but the amount they took out over a two month period, was paid back over a 12 month period.
You have to keep an eye on these utility companies, they know most people don't keep an eye on their accounts and use auto pay?
Some meter covers are very easy to open with a key you can buy at home depot or similar.The problem that the OP is trying to work around is that he does not have access to the meter.
