Hi there. Water consumption in my house is high since we bought the house. No leaks for sure (when we left for a month, the usage was none); also in the past 1-2 years, we've renovated all bathrooms, installed water efficient toilets, showers, faucets, etc.. No long showers, no frequent laundries either. Per water company data, our water consumption is above average and for sure higher than my neighbors I talked to (with bigger houses, more habitants, daily yard watering).
And no, I don't use sprinklers. I occasionally water a few plants with a hose.
I suspect that a water meter faulty it shows e.g. 2x more what we use. Technically, I don't have access to it (it is in one of those locked boxes buried at the property line). I called the water company asking for a validation, but I was disregarded.
What's the procedure of conducting an audit of actual use and who can do that? I would prefer NOT to cut my main water line to install the 2nd meter inside my house to compare indications.
Thoughts?
Thanks!
J.
Thoughts?
Thanks!
J.
