I'm sure how it is there but all that I have done where the fitting off the meter to the house is compression fitting. Where as there is a 3/4" 90deg fitting. then between the fitting there is a rubber washer and is coupled with a nut. Most water jurisdictions require a licensed plumber to make this connection and must have rigid pipe out of the meter can. Believe me when I tell you to check with you local water service provider. If you break anything in the meter can to include service to the meter it can get very EXPENSIVE.
Also depending on service requirements when the can was set fitting sizes may be different than 3/4"
So, maybe I just won't touch the meter at all.
I could just replace from the first joint onwards. There is that old ball valve that I would like to replace, but if it's going to require hiring a licensed plumber, then I'll leave it alone too.
I hadn't thought much of damage to the meter. It seems to be a very solid can (as you call it).
I'll take another look at it tomorrow morning and decide how much I really need to replace.
Thanks for the advice
Edit: I looked up my township code, and found absolutely nothing about plumbing. If it's going to be an issue, it might be with the water utility, but not the township, as it appears to me.
This said, my 10yr old water heater does have a tag indicating that it passed plumbing inspection. Perhaps because it is a gas appliance?
Maybe I'm not looking deeply enough into the township code.
FW
