I have cpvc water lines on slab constrction in an upstate NY cottage.
There will be periods of freezing without any heat.
I was planning on adding fittings to the start of the run to blow out the lines with my 8 gallon compressor. I do my own irrigation lines (although it takes a few shots due to the small sized compressor .)
i was wondering how cold it would get at the level of the slab?
I have placed pipe insulation on the 3/4 lines. Should I put rigid foam under the pipe as well?
There is some slope to the lines. There are no pipes in the outside walls.
Should I insulate the inside walls where the 1/2 lines are supplied to the fixtures?
Will I be ok?
Will I be ok?
