Let me explain current situation first.
I had a water leaking issue in the ground floor from the side of my town home where vinyl siding was below grade as you see it in the first picture attached. I dug up soil so siding is now above grade. There were heavy rains over the past weeks, and no leaking or drainage issue so far. My neighbor plans to do some landscaping in their backyard to prevent soil erosion. BTW there's no basement as it's town home.
My unit bumped out toward backyard by two feet and is sitting lower than my neighbor's unit by one and a half feet, so vinyl inside corner trim meets my neighbor's concrete foundation. Since I dug up dirt, I see light coming through the gap between siding/cement board and neighbor's concrete foundation (the second and third pictures).
Here are my questions.
1. I see some dirt behind vinyl siding inside corner trim (picture 4) and between siding and concrete foundation, Also I guess there could be some dirt between siding and cement board. How can I clean them up? Just open up sidings and brush dirt off?
2. How can I seal the vertical gap between siding corner trim and concrete foundation? I see that The flange of siding corner trim on concrete side had been removed.
3. There was a hole for cable for satellite dish, and I guess it wasn't sealed well, so water seeped thought it. Now I removed cable and closed the hole, but I found a small section of rotted plywood at the bottom corner. How can I fix? Should I event bother to fix it?
Thanks!!
Thanks!!
