Hi Everyone! Thanks in advance for any advice that you can give.
We're looking to finish our basement, and have a small issue with water leaking through the walls.
. It is damp to the touch, but I wouldn't consider this a full-on leak. It's almost as if the water is just leeching through certain parts of the foundation wall. (Apparently I can't post pics yet, so I put it in my album that you can view under my profile)
I've reached out to a few professionals in our area that specialize in basements as well as other contractor friends I have. Everyone seems to suggest something different, so I'm reaching out to everyone here to see if I can get a consensus on the issue.
To give some information on our house that may help. It's a modular home that we got about 5 years ago. The exterior of the foundation walls were waterproofed, and covered with plastic, and then backfilled with approx. 1 foot of gravel up to ground level. The ground slopes away from the house on all sides except for the wall that is leaking water, and the ground is nearly perfectly flat on that side.There is a deck attached to the house directly above the offending wall, so doing any work on the exterior of the home to divert the water is pretty much impossible due to cost.
There are no issues with the downspouts. All gutters flow into a pvc drainage system that exits about 50 ft from the house. We did have the cinder block walls filled with concrete and rebar prior to the house being set on the foundation. I've taped aluminum foil to the wall to determine if the problem is from the outside or inside, and the majority of the water seems to be flowing through the exterior, but I did have some condensation on the interior side of the aluminum foil as well.
There is a perforated pipe that is attached to both the interior and exterior of the footer that is tied into the drainage system that feeds away from the house which is basically an interior drain tile system minus the sump pump, but the home is built into the side of a mountain so we're able to flow anything that hits the interior drain tile away from the house via gravity. I don't imagine we would ever have issues with hydrostatic pressure pushing water up through the floor because any water is going downhill and fast.
When excavating for the home, the previous owner said there was a rock shelf where he originally wanted to put the house, so he had to move the foundation to cut down on costs. Some of the professionals seems to think the groundwater may be hitting that rock shelf, and flowing straight into the basement wall and that the exterior waterproofing wasn't up to snuff and that the drainage system is taking care of most of it, but it just can't keep up completely and some is leeching through the wall.
Some have suggested that drylok latex waterproofer will take care of the issues since it's not so bad. Some have said to absolutely not use drylok, and that we should put 12-15 mil plastic on the walls and that's all we need. Some have suggested both, and some have suggested that we do an additional full drain tile system with a sump pump.
It may be worth mentioning that we plan on putting a home theater in the basement, with carpet, and I'm worried about moisture issues with that.
Thanks again for any help you can offer. I really appreciate it!
