...except when they're not!
I installed a new tankless natural-gas waterheater on a time-crunch, which means I didn't get to do it "right." It works, but I need to take care of a couple of important things, and I could use some advice.
First, the vital statistics. The new water heater is an Eccotemp FVi12, which is a small 74,500 BTU unit, just the right size for us. We don't use a ton of water, and the old house only has one full bathroom, so it's not like we need a high-demand unit. Trouble is, all this thing's connectors are smaller-than-usual sizes.
Here's what I *didn't* do yet: I need to install the isolation valves, which I can't find, because the thing runs off a half-inch line instead of 3/4. Question one is, does anybody know where I can even FIND a 1/2" valve kit? If not, what happens if I install a reducer and use 3/4-inch valves? Is that gonna mess with my flow/pressure/etc.? And if I hook up a descaler--which comes with a 3/4-inch hose--and use an adaptor to hook it up to a 1/2-inch valve, is that gonna mess up my water heater? I plumbed in pex, and I planned ahead for cutting out some line for the valves, I just don't *have* them. If I can't attach the isolation kit, how should I do the T&P valve, and is there an easy way to do some kind of diverter so I can still use a descaler?
Second question, with preface: I'm not afraid of plumbing, but I don't know everything, and I have a healthy respect for gas lines. I plumbed gas to the unit, and did my leak-checks. Found one at the flare coupling at the end of the flex line, and fixed that. I don't see any more bubbles, and I don't *think* I smell gas, but paranoia rears its head. I don't have the money to hire a plumber, and I needed the unit installed, so I just did it, and I've done all the due diligence that I can... but I was wondering what else I can or should do to double-check that there aren't any leaks. What's the gold standard for ensuring leak-free gas plumbing?
And the third question, which is one I actually didn't quite think through before jumping in. The unit is installed in the basement, and per the manufacturer's specs, there's plenty of air available for combustion. However... we also have a wood-stove down there, which is the heat-source for the house. How do you do the calculations to figure out whether or not you need a dedicated air source for combustion appliances?
Finally, one last thing about gas. The old gas piping is kind of... old and weird, and now that the water heater has moved, I'm going to clean it up some. The three appliances that use gas are the range, the water heater, and the dryer. The gas line comes in, turns parallel to the wall, and runs past a tee to the range, past the water heater, to the dryer, so there aren't really many turns and complicated runs. Right now, it drops to 3/4" from 1" at that tee, then steps down again from 3/4 to 1/2 after the water heater. Does that seem pretty reasonable, or should I do some reading and calculations?
Thanks so much for any advice!
El Barbón, refreshed after the first hot shower of the new water heater
The old water heater is a martyr to the cause; I retired it because it was leaking a disturbing amount of water and I don't want a swimming pool for a basement.
